''FlyVIZ'': A Novel Display Device to Provide Humans with 360o Vision by Coupling Catadioptric Camera with HMD. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Have you ever dreamed of having eyes in the back of your head? In this paper we present a novel display device called FlyVIZ which enables humans to experience a real-time 360° vision of their surroundings for the first time. To do so, we combine a panoramic image acquisition system (positioned on top of the user's head) with a Head-Mounted Display (HMD). The omnidirectional images are transformed to fit the characteristics of HMD screens. As a result, the user can see his/her surroundings, in real-time, with 360° images mapped into the HMD field-of- view. We foresee potential applications in different fields where augmented human capacity (an extended field-of-view) could benefit, such as surveillance, security, or entertainment. FlyVIZ could also be used in novel perception and neuroscience studies.
2012_vrst_ardouin.pdf (848.13 Ko) Télécharger le fichier
hal-00750613 , version 1 (11-11-2012)
  • HAL Id : hal-00750613 , version 1
Jérôme Ardouin, Anatole Lécuyer, Maud Marchal, Clément Riant, Eric Marchand. ''FlyVIZ'': A Novel Display Device to Provide Humans with 360o Vision by Coupling Catadioptric Camera with HMD.. ACM Symp. on Virtual Reality Software and Technology, VRST'12, 2012, Toronto, Canada. ⟨hal-00750613⟩
493 Consultations
440 Téléchargements
