On the solvability conditions for the diffusion equation with convection terms. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Communications on Pure and Applied Mathematics Année : 2012
Linear second order elliptic equation describing heat or mass di®usion and convection on a given velocity ¯eld is considered in R3. The corresponding operator L may not satisfy the Fredholm property. In this case, solvability conditions for the equation Lu = f are not known. In this work, we derive solvability conditions in H2(R3) for the non self-adjoint problem by relating it to a self-adjoint SchrÄodinger type operator, for which solvability con- ditions are obtained in our previous work
Fichier non déposé
hal-00753098 , version 1 (17-11-2012)
  • HAL Id : hal-00753098 , version 1
Vitaly Volpert, Vitali Vougalter. On the solvability conditions for the diffusion equation with convection terms.. Communications on Pure and Applied Mathematics, 2012, 11 (1), pp.365--373. ⟨hal-00753098⟩
498 Consultations
0 Téléchargements
