Observability and Detectability of Singular Linear Systems with Unknown Inputs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2013
In this paper the strong observability and strong detectability of a general class of singular linear systems with unknown inputs are tackled. The case when the matrix pencil is non-regular is comprised (i.e., more than one solution for the differential equation is allowed). It is shown that, under suitable assumptions, the original problem can be studied by means of a regular (non-singular) linear system with unknown inputs and algebraic constraints. Thus, it is shown that for purposes of analysis, the algebraic equations can be included as part of an extended system output. Based on this analysis, we obtain necessary and sufficient conditions guaranteeing the observability (or detectability) of the system in terms of the zeros of the system matrix. Corresponding algebraic conditions are given in order to test the observability and detectability. A formula is provided that expresses the state as high order derivative of a function of the output, which allows for the reconstruction of the actual state vector. It is shown that the unknown inputs may be reconstructed also.
Automatique
ObsSLS_Automatica_Final (1).pdf (630.49 Ko) Télécharger le fichier
hal-00753706 , version 1 (08-03-2017)
Francisco Javier Bejarano, Thierry Floquet, Wilfrid Perruquetti, Gang Zheng. Observability and Detectability of Singular Linear Systems with Unknown Inputs. Automatica, 2013, 49 (3), pp.6. ⟨10.1016/j.automatica.2012.11.043⟩. ⟨hal-00753706⟩
323 Consultations
340 Téléchargements
