On the Reification of Global Constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Constraints Année : 2013
We introduce a simple idea for deriving reified global constraints in a systematic way. It is based on the observation that most global constraints can be reformulated as a conjunction of total function constraints together with a constraint that can be easily reified.
hal-00754252 , version 1 (20-11-2012)
Nicolas Beldiceanu, Mats Carlsson, Pierre Flener, Justin Pearson. On the Reification of Global Constraints. Constraints, 2013, 18 (1), pp.1-6. ⟨10.1007/s10601-012-9132-0⟩. ⟨hal-00754252⟩
129 Consultations
0 Téléchargements
