Approximation of stationary solutions to SDEs driven by multiplicative fractional noise - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Stochastic Processes and their Applications Année : 2014
In a previous paper, we studied the ergodic properties of an Euler scheme of a stochastic differential equation with a Gaussian additive noise in order to approximate the stationary regime of such equation. We now consider the case of multiplicative noise when the Gaussian process is a fractional Brownian Motion with Hurst parameter H>1/2 and obtain some (functional) convergences properties of some empirical measures of the Euler scheme to the stationary solutions of such SDEs.
cohen_panloup_tindel_revision_spa.pdf (322.79 Ko) Télécharger le fichier
hal-00754368 , version 1 (20-11-2012)
hal-00754368 , version 2 (19-11-2013)
Serge Cohen, Fabien Panloup, Samy Tindel. Approximation of stationary solutions to SDEs driven by multiplicative fractional noise. Stochastic Processes and their Applications, 2014, 124 (3), pp.1197-1225. ⟨10.1016/j.spa.2013.11.004⟩. ⟨hal-00754368v2⟩
558 Consultations
472 Téléchargements
