Optimizing the anaerobic digestion of microalgae in a coupled process - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This work is devoted to maximizing the production of methane in a bioreactor coupling an anaerobic digester and a culture of micro-algae limited by light. The decision parameter is the dilution rate which is chosen as a control, and we enforce periodic constraints in order to repeat the same operation every day. The system is gathered into a three-dimensional system taking into account a day-night model of the light in the culture of micro-algae. Applying Pontryagin maximum principle, the necessary conditions on optimal trajectories indicate that the control consists of bang and/or singular arcs. We provide numerical simulations by both direct and indirect methods, which show the link between the light model and the structure of optimal solutions.
ecc.pdf (267.27 Ko) Télécharger le fichier
hal-00754971 , version 1 (13-02-2013)
  • HAL Id : hal-00754971 , version 1
  • PRODINRA : 316455
  • WOS : 000332509701100
Térence Bayen, Francis Mairet, Pierre Martinon, Matthieu Sebbah. Optimizing the anaerobic digestion of microalgae in a coupled process. 13th European Control Conference, Jul 2013, Zurich, Switzerland. pp.6. ⟨hal-00754971⟩
629 Consultations
260 Téléchargements
