Optimal stopping for partially observed piecewise-deterministic Markov processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Stochastic Processes and their Applications Année : 2013
This paper deals with the optimal stopping problem under partial observation for piecewise-deterministic Markov processes. We first obtain a recursive formulation of the optimal filter process and derive the dynamic programming equation of the partially observed optimal stopping problem. Then, we propose a numerical method, based on the quantization of the discrete-time filter process and the inter-jump times, to approximate the value function and to compute an actual $\epsilon$-optimal stopping time. We prove the convergence of the algorithms and bound the rates of convergence.
hal-00755052 , version 1 (20-11-2012)
Adrien Brandejsky, Benoîte de Saporta, François Dufour. Optimal stopping for partially observed piecewise-deterministic Markov processes. Stochastic Processes and their Applications, 2013, 123, pp.3201-3238. ⟨10.1016/j.spa.2013.03.006⟩. ⟨hal-00755052⟩
186 Consultations
0 Téléchargements
