Spectral and condition number estimates of the acoustic single-layer operator for low-frequency multiple scattering in dilute media - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Methods in Applied Mechanics and Engineering Année : 2013
The aim of this paper is to develop an analysis of the distribution of the eigenvalues of the acoustic single-layer potential for various low frequency two-dimensional multiple scattering problems. The obstacles are supposed to be distant (dilute media). In \cite{ThierryThesis}, it is shown that an approach based on the Gershgorin disks provides limited spectral information. We therefore introduce an alternative approach by applying the power iteration method to the limit matrix (associated with the zero order spatial modes) which results in satisfactory estimates. All these approximations are built for circular cylinders and formally extended to ellipses and rectangles for linear boundary element methods with non uniform meshes. This study is completed in \cite{AntoineThierryPart2} by spectral estimates for the case of close obstacles.
PaperEstimates1Revised.pdf (1.18 Mo) Télécharger le fichier
hal-00755645 , version 1 (21-11-2012)
Xavier Antoine, Bertrand Thierry. Spectral and condition number estimates of the acoustic single-layer operator for low-frequency multiple scattering in dilute media. Computer Methods in Applied Mechanics and Engineering, 2013, 265, pp.242-256. ⟨10.1016/j.cma.2012.04.017⟩. ⟨hal-00755645⟩
288 Consultations
156 Téléchargements
