Numerical simulation of horizontal-axis wind turbine (HAWT) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The aim of this study is to estimate the wind power that can be extracted by an horizontal-axis wind turbine (HAWT) as a function of upstream wind. The incompressible Navier-Stokes equations are solved on a fixed cartesian mesh via a second-order accurate scheme in space and time. The turning blades and the mast are modeled by a penalization term in the governing equations within a collocated Chorin-Temam fractional time integration algorithm. The turbulence model is based on a large-eddy simulation model initially fitted on experimental data. This numerical procedure allows massive parallelization by using existing distributed linear-algebra libraries. The test case under consideration is the two blades NREL ametest wind turbine that has been intensively studied in wind tunnel.
Fichier non déposé
hal-00756423 , version 1 (23-11-2012)
  • HAL Id : hal-00756423 , version 1
Michel Bergmann, Angelo Iollo. Numerical simulation of horizontal-axis wind turbine (HAWT). International Conference on Computational Fluid Dynamics, Jul 2012, Mauna Lani Bay Hotel,Hawaii, United States. ⟨hal-00756423⟩
109 Consultations
0 Téléchargements
