Wavelet-based Semblance for P300 Single-trial Detection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Electroencephalographic signals are usually contaminated by noise and artifacts making difficult to detect Event-Related Potential (ERP), specially in single trials. Wavelet denoising has been successfully applied to ERP detection, but usually works using channels information independently. This paper presents a new adaptive approach to denoise signals taking into account channels correlation in the wavelet domain. Moreover, we combine phase and amplitude information in the wavelet domain to automatically select a temporal window which increases class separability. Results on a classic Brain-Computer Interface application to spell characters using P300 detection show that our algorithm has a better accuracy with respect to the VisuShrink wavelet technique and XDAWN algorithm among 22 healthy subjects, and a better regularity than XDAWN.
SaavedraBioSignal13.pdf (164.06 Ko) Télécharger le fichier
hal-00756563 , version 1 (23-11-2012)
  • HAL Id : hal-00756563 , version 1
Carolina Saavedra, Laurent Bougrain. Wavelet-based Semblance for P300 Single-trial Detection. BIOSIGNAL - international conference on Bio-Inspired Systems and Signal Processing - 2013, Feb 2013, Barcelone, Spain. ⟨hal-00756563⟩
234 Consultations
400 Téléchargements
