s'authentifier
version française rss feed
hal-00758025, version 1
Efficient fault monitoring with Collaborative Prediction
Dawei Feng 1, Cecile Germain-Renaud (, http://www.lri.fr/~cecile/communications-english.html) 12, Tristan Glatard () 3
Journées scientifiques mésocentres et France Grilles (2012)
Résumé : Isolating users from the inevitable faults in large distributed systems is critical to Quality of Experience. We formulate the problem of probe selection for fault prediction based on end-to-end probing as a Collaborative Prediction (CP) problem. On an extensive experimental dataset from the EGI grid, the combination of the Maximum Margin Matrix Factorization approach to CP and Active Learning shows excellent performance, reducing the number of probes typically by 80% to 90%.
  • Domaine : Informatique/Calcul parallèle, distribué et partagé
    Informatique/Apprentissage
  • hal-00758025, version 1
  • oai:hal.inria.fr:hal-00758025
  • Contributeur :
  • Soumis le : Mardi 27 Novembre 2012, 21:30:56
  • Dernière modification le : Mercredi 28 Novembre 2012, 10:39:32
tous les articles de la base du CCSd...
