Towards a new speech event detection approach for landmark-based speech recognition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this work, we present a new approach for the classification and detection of speech units for the use in landmark or eventbased speech recognition systems. We use segmentation to model any time-variable speech unit by a fixed-dimensional observation vector, in order to train a committee of boosted decision stumps on labeled training data. Given an unknown speech signal, the presence of a desired speech unit is estimated by searching for each time frame the corresponding segment, that provides the maximum classification score. This approach improves the accuracy of a phoneme classification task by 1.7%, compared to classification using HMMs. Applying this approach to the detection of broad phonetic landmarks inside a landmark-driven HMM-based speech recognizer significantly improves speech recognition.
slt8_final.pdf (174.69 Ko) Télécharger le fichier
hal-00758424 , version 1 (28-11-2012)
  • HAL Id : hal-00758424 , version 1
Stefan Ziegler, Bogdan Ludusan, Guillaume Gravier. Towards a new speech event detection approach for landmark-based speech recognition. SLT - Workshop on Spoken Language Technology, 2012, United States. ⟨hal-00758424⟩
304 Consultations
269 Téléchargements
