PANORAMA: A 3D Shape Descriptor based on Panoramic Views for Unsupervised 3D Object Retrieval - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Computer Vision Année : 2010
We present a novel 3D shape descriptor that uses a set of panoramic views of a 3D object which describe the position and orientation of the object's surface in 3D space. We obtain a panoramic view of a 3D object by projecting it to the lateral surface of a cylinder parallel to one of its three principal axes and centered at the centroid of the object. The object is projected to three perpendicular cylinders, each one aligned with one of its principal axes in order to capture the global shape of the object. For each projection we compute the corresponding 2D Discrete Fourier Trans- form as well as 2D Discrete Wavelet Transform. We further increase the retrieval performance by employ- ing a local (unsupervised) relevance feedback technique that shifts the descriptor of an object closer to its clus- ter centroid in feature space. The effectiveness of the proposed 3D object retrieval methodology is demon- strated via an extensive evaluation in standard bench- marks that clearly shows better performance against state-of-the-art 3D object retrieval methods.
p34.pdf (4.8 Mo) Télécharger le fichier
hal-00758978 , version 1 (30-11-2012)
Panagiotis Papadakis, Ioannis Pratikakis, Theoharis Theoharis, Stavros Perantonis. PANORAMA: A 3D Shape Descriptor based on Panoramic Views for Unsupervised 3D Object Retrieval. International Journal of Computer Vision, 2010, ⟨10.1007/s11263-009-0281-6⟩. ⟨hal-00758978⟩
108 Consultations
788 Téléchargements
