Factorisation of RSA-704 with CADO-NFS - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2012
We give details of the factorization of RSA-704 with CADO-NFS. This is a record computation with publicly available software tools. The aim of this experiment was to stress CADO-NFS --- which was originally designed for 512-bit factorizations --- for larger inputs, and to identify possible rooms of improvement.
369.pdf (72.92 Ko) Télécharger le fichier
hal-00760322 , version 1 (03-12-2012)
  • HAL Id : hal-00760322 , version 1
Shi Bai, Emmanuel Thomé, Paul Zimmermann. Factorisation of RSA-704 with CADO-NFS. 2012. ⟨hal-00760322⟩
519 Consultations
687 Téléchargements
