Proposition of Dynamic Virtual Link for IPv6 GeoNetworking (GN6) in ETSI - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2012
First, we describe the limitation of Draft EN 302 636-6-1 V0.1.2 (2012-11). Note that this study is based on year November 2012 versions of the ETSI Standards and that the standards constantly evolve. As a result, parameters, primitives and virtual links on GN6ASL may have changed at the time of reading. To overcome the limitation, we propose Dynamic Virtual Link (DVL).
dynamic-virtual-link-201211.pdf (323.86 Ko) Télécharger le fichier
hal-00760772 , version 1 (04-12-2012)
  • HAL Id : hal-00760772 , version 1
Manabu Tsukada, Masatoshi Kakiuchi, Thierry Ernst. Proposition of Dynamic Virtual Link for IPv6 GeoNetworking (GN6) in ETSI. 2012. ⟨hal-00760772⟩
243 Consultations
294 Téléchargements
