A New Approach to Classification by Means of Jumping Emerging Patterns - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Classification is one of the important fields in data analysis. Generating concept-based (JSM) hypotheses is a well-known approach to this task. Although the accuracy of this approach is quite good, the coverage is often insufficient. In this paper a new classification approach is presented. The approach is based on the similarity of an object to be classified to the current set of hypotheses: it attributes the new object to the class that minimizes the set of new hypotheses when a new object is added to the training set. The proposed approach provides a better coverage in comparison with the classical approach.
mining-EP-paper.pdf (221.69 Ko) Télécharger le fichier
hal-00761602 , version 1 (05-12-2012)
  • HAL Id : hal-00761602 , version 1
Aleksey Buzmakov, Sergei O. Kuznetsov, Amedeo Napoli. A New Approach to Classification by Means of Jumping Emerging Patterns. FCA4AI: International Workshop "What can FCA do for Artificial Intelligence?" - 2012, Dec 2012, Montpellier, France. ⟨hal-00761602⟩
158 Consultations
98 Téléchargements
