T-coercivity for the Maxwell problem with sign-changing coefficients - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Communications in Partial Differential Equations Année : 2014
In this paper, we study the time-harmonic Maxwell problem with sign-changing permittivity and/or permeability, set in a domain of R^3. We prove, using the T-coercivity approach, that the well-posedness of the two canonically associated scalar problems, with Dirichlet and Neumann boundary conditions, implies the well-posedness of the Maxwell problem. This allows us to give simple and sharp criteria, obtained in the study of the scalar cases, to ensure that the Maxwell transmission problem between a classical dielectric material and a negative metamaterial is well-posed.
BoCC12aHal.pdf (1.41 Mo) Télécharger le fichier
hal-00762275 , version 1 (06-12-2012)
  • HAL Id : hal-00762275 , version 1
Anne-Sophie Bonnet-Ben Dhia, Lucas Chesnel, Patrick Ciarlet. T-coercivity for the Maxwell problem with sign-changing coefficients. Communications in Partial Differential Equations, 2014. ⟨hal-00762275⟩
884 Consultations
301 Téléchargements
