A Privacy Preserving Distributed Reputation Mechanism - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Reputation systems allow to estimate the trustworthiness of entities based on their past behavior. Electronic commerce, peer-to-peer routing and collaborative environments, just to cite a few, highly benefit from using reputation systems. To guarantee an accurate estimation, reputation systems typically rely on a central authority, on the identification and authentication of all the participants, or both. In this paper, we go a step further by presenting a distributed reputation mechanism which is robust against malicious behaviors and that preserves the privacy of its clients. Guaranteed error bounds on the estimation are provided.
drspp-RR.pdf (267.9 Ko) Télécharger le fichier
hal-00763212 , version 1 (10-12-2012)
hal-00763212 , version 2 (13-12-2012)
hal-00763212 , version 3 (14-12-2012)
  • HAL Id : hal-00763212 , version 3
Emmanuelle Anceaume, Gilles Guette, Paul Lajoie-Mazenc, Nicolas Prigent, Valérie Viet Triem Tong. A Privacy Preserving Distributed Reputation Mechanism. International Conference on communications (ICC), Jun 2013, Budapest, France. 6 p. ⟨hal-00763212v3⟩
460 Consultations
1919 Téléchargements
