UMPa: A Multi-objective, multi-level partitioner for communication minimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2013
We propose a directed hypergraph model and a refinement heuristic to distribute communicating tasks among the processing units in a distributed memory setting. The aim is to achieve load balance and minimize the maximum data sent by a processing unit. We also take two other communication metrics into account with a tie-breaking scheme. With this approach, task distributions causing an excessive use of network or a bottleneck processor which participates to almost all of the communication are avoided. We show on a large number of problem instances that our model improves the maximum data sent by a processor up to 34% for parallel environments with 4, 16, 64 and 256 processing units compared to the state of the art which only minimizes the total communication volume.
umpa-dimacs.pdf (398.88 Ko) Télécharger le fichier
hal-00763563 , version 1 (19-12-2019)
Umit V. Catalyurek, Mehmet Deveci, Kamer Kaya, Bora Uçar. UMPa: A Multi-objective, multi-level partitioner for communication minimization. David A. Bader; Henning Meyerhenke; Peters Sanders; Dorothea Wagner. Graph Partitioning and Graph Clustering 2012, 588, AMS, pp.53--66, 2013, Contemporary Mathematics, ⟨10.1090/conm/588/11704⟩. ⟨hal-00763563⟩
192 Consultations
158 Téléchargements
