Formal Expression of Sensitivity and Energy Relationship in the Context of the Coupling Matrix - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Microwave Theory and Techniques Année : 2012
Precise formulas to express the formal relationship between the time average stored energy in the resonators of a low-pass filter network and the sensitivity of the reflection S -parameter with respect to the coupling matrix terms are demonstrated in this paper, considering the normalized frequency axis. These relationships are found in the modern context of the N+2 coupling matrix, and for both diagonal and general nondiagonal coupling elements of the matrix. The results are valid for any type of coupling topology represented by the N+2 coupling matrix. Different examples are included as validation. Furthermore, important implications and applications derived from the new relationships are highlighted.
bare_jrnl.pdf (302.01 Ko) Télécharger le fichier
hal-00763652 , version 1 (17-01-2020)
Monica Martinez-Mendoza, Fabien Seyfert, Christoph Ernst, Alejandro Alvarez-Melcon. Formal Expression of Sensitivity and Energy Relationship in the Context of the Coupling Matrix. IEEE Transactions on Microwave Theory and Techniques, 2012, 60 (11), pp.3369 - 3375. ⟨10.1109/TMTT.2012.2216286⟩. ⟨hal-00763652⟩
Collections
INRIA INRIA2
147 Consultations
116 Téléchargements
