A well-balanced numerical scheme for a one dimensional quasilinear hyperbolic model of chemotaxis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Communications in Mathematical Sciences Année : 2014
We introduce a numerical scheme to approximate a quasi-linear hyperbolic system which models the movement of cells under the influence of chemotaxis. Since we expect to find solutions which contain vacuum parts, we propose an upwinding scheme which handles properly the presence of vacuum and, besides, which gives a good approximation of the time asymptotic states of the system. For this scheme we prove some basic analytical properties and study its stability near some of the steady states of the system. Finally, we present some numerical simulations which show the dependence of the asymptotic behavior of the solutions upon the parameters of the system.
wb_gp.pdf (703.55 Ko) Télécharger le fichier
hal-00764086 , version 1 (12-12-2012)
  • HAL Id : hal-00764086 , version 1
Roberto Natalini, Magali Ribot, Monika Twarogowska. A well-balanced numerical scheme for a one dimensional quasilinear hyperbolic model of chemotaxis. Communications in Mathematical Sciences, 2014, 12 (1), pp.13-39. ⟨hal-00764086⟩
265 Consultations
265 Téléchargements
