Quick Detection of Nodes with Large Degrees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Our goal is to quickly find top $k$ lists of nodes with the largest degrees in large complex networks. If the adjacency list of the network is known (not often the case in complex networks), a deterministic algorithm to find the top $k$ list of nodes with the largest degrees requires an average complexity of $\mbox{O}(n)$, where $n$ is the number of nodes in the network. Even this modest complexity can be very high for large complex networks. We propose to use the random walk based method. We show theoretically and by numerical experiments that for large networks the random walk method finds good quality top lists of nodes with high probability and with computational savings of orders of magnitude. We also propose stopping criteria for the random walk method which requires very little knowledge about the structure of the network.
Paper8WAW12.pdf (226.37 Ko) Télécharger le fichier
hal-00764220 , version 1 (12-12-2012)
Konstantin Avrachenkov, Nelly Litvak, Marina Sokol, Don Towsley. Quick Detection of Nodes with Large Degrees. WAW'12: The 9th Workshop on Algorithms and Models for the Web Graph, Jun 2012, Halifax, Canada. pp.54-65, ⟨10.1007/978-3-642-30541-2_5⟩. ⟨hal-00764220⟩
Collections
INRIA INRIA2
156 Consultations
151 Téléchargements
