Dynamic Mesh Optimization for Free Surfaces in Fluid Simulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
David Lopez
  • Fonction : Auteur
  • PersonId : 934045
Bruno Lévy
We propose a new free surface fluid front tracking algorithm. Based on Centroidal Voronoi Diagram optimizations, our method creates a serie of either isotropic or anisotropic meshes that confroms with an evolving surface.
fluids.pdf (1.84 Mo) Télécharger le fichier
hal-00764267 , version 1 (12-12-2012)
  • HAL Id : hal-00764267 , version 1
David Lopez, Bruno Lévy. Dynamic Mesh Optimization for Free Surfaces in Fluid Simulation. IMR - 21th international meshing roundtable - 2012, Xiangmin Jiao and Jean-Christophe Weill, Oct 2012, San José, United States. pp.1-5. ⟨hal-00764267⟩
173 Consultations
195 Téléchargements
