Padé approximants to certain elliptic-type functions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal d'analyse mathématique Année : 2013
Given non-collinear points a_1, a_2, a_3, there is a unique compact, say \Delta, that has minimal logarithmic capacity among all continua joining a_1, a_2, and a_3. For h be a complex-valued non-vanishing Dini-continuous function on \Delta, we consider f_h(z) := (1/\pi i)\int_\Delta h(t)/(t-z) dt/w^+(t), where w(z) := \sqrt{\prod_{k=0}^3(z-a_k)} and w^+ the one-sided value according to some orientation of \Delta. In this work we present strong asymptotics of diagonal Padé approximants to f_h and describe the behavior of the spurious pole and the regions of locally uniform convergence from a generic perspective.
hal-00764314 , version 1 (12-12-2012)
Laurent Baratchart, Maxim Yattselev. Padé approximants to certain elliptic-type functions. Journal d'analyse mathématique, 2013, 121 (1), pp.31-86. ⟨10.1007/s11854-013-0027-9⟩. ⟨hal-00764314⟩
Collections
INRIA INRIA2
182 Consultations
0 Téléchargements
