An IEEE-1588 compatible RADclock - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The RADclock is an open source software clock that is highly robust to latency variability. A limitation up to now has been that it could only be used with NTP servers, and was unable to take advantage of IEEE-1588 enabled devices, including PTP masters and NICs with hardware timestamping. This paper benchmarks an early implementation of PTP support for RADclock, with and without hardware timestamping. We evaluate performance under both nominal and stressed conditions against alternative software clients ptpd and timekeeper and find that it compares very well.
hal-00765158 , version 1 (14-12-2012)
Matthew Davis, Benjamin Villain, Julien Ridoux, Anne-Cécile Orgerie, Darryl Veitch. An IEEE-1588 compatible RADclock. International IEEE Symposium on Clock Synchronization for Measurement Control and Communication (ISPCS), Sep 2012, San Francisco, United States. 6 pp, ⟨10.1109/ISPCS.2012.6336624⟩. ⟨hal-00765158⟩
425 Consultations
0 Téléchargements
