Towards an analysis framework for tasks with probabilistic execution times and probabilistic inter-arrival times - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2012
Dorin Maxim
  • Fonction : Auteur
  • PersonId : 884508
Liliana Cucu
  • Fonction : Auteur
  • PersonId : 844766
In this paper we investigate the problem of calculating the response time distribution for real-time tasks with probabilistic worst-case execution times, probabilistic inter-arrival times and probabilistic deadlines. We propose a definition for the probabilistic deadlines and a first discussion on the response time calculation.
WiP_ECRTS_final.pdf (293.52 Ko) Télécharger le fichier
hal-00766019 , version 1 (17-12-2012)
  • HAL Id : hal-00766019 , version 1
Dorin Maxim, Liliana Cucu. Towards an analysis framework for tasks with probabilistic execution times and probabilistic inter-arrival times. 2012. ⟨hal-00766019⟩
84 Consultations
123 Téléchargements
