The buffered chemostat with non-monotonic response functions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We study how a particular spatial structure with a buffer impacts the number of equilibria and their stability in the chemostat model. We show that the occurrence of a buffer can allow a species to persist or on the opposite to go extinct, depending on the characteristics of the buffer. For non-monotonic response functions, we characterize the buffered configurations that make the chemostat dynamics globally asymptotically stable, while this is not possible with single, serial or parallel vessels of the same total volume and input flow. These results are illustrated with the Haldane kinetic function.
buffered_chemostat-hal2.pdf (284.98 Ko) Télécharger le fichier
hal-00766243 , version 1 (17-12-2012)
hal-00766243 , version 2 (25-05-2014)
Alain Rapaport, Ihab Haidar, Jérôme Harmand. The buffered chemostat with non-monotonic response functions. 9th IFAC Symposium on Nonlinear Control Systems (NOLCOS 2013), Sep 2013, Toulouse, France. pp.181-186, ⟨10.3182/20130904-3-FR-2041.00039⟩. ⟨hal-00766243v2⟩
569 Consultations
313 Téléchargements
