A Formal Semantics for Weighted Ontology Mappings - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ontology mappings are often assigned a weight or confidence factor by matchers. Nonetheless, few semantic accounts have been given so far for such weights. This paper presents a formal semantics for weighted mappings between different ontologies. It is based on a classificational interpretation of mappings: if O1 and O2 are two ontologies used to classify a common set X, then mappings between O1 and O2 are interpreted to encode how elements of X classified in the concepts of O1 are re-classified in the concepts of O2, and weights are inter- preted to measure how precise and complete re-classifications are. This semantics is justifiable by extensional practice of ontology matching. It is a conservative ex- tension of a semantics of crisp mappings. The paper also includes properties that relate mapping entailment with description logic constructors.
atencia2012c.pdf (351.67 Ko) Télécharger le fichier
hal-00768413 , version 1 (21-12-2012)
Manuel Atencia, Alexander Borgida, Jérôme Euzenat, Chiara Ghidini, Luciano Serafini. A Formal Semantics for Weighted Ontology Mappings. ISWC 2012 - International Semantic Web Conference, Nov 2012, Boston, MA, United States. pp.17-33, ⟨10.1007/978-3-642-35176-1_2⟩. ⟨hal-00768413⟩
506 Consultations
320 Téléchargements
