Linked data from your pocket - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The paper describes a lightweight general purpose RDF framework for Android. It allows to deal uniformly with RDF, whether it comes from the web or from applications inside the device. It extends the Android content provider framework and introduces a transparent URI dereferencing scheme allowing for exposing device content as linked data.
paper_3.pdf (334.95 Ko) Télécharger le fichier
hal-00768418 , version 1 (21-12-2012)
  • HAL Id : hal-00768418 , version 1
Jérôme David, Jérôme Euzenat, Maria Rosoiu. Linked data from your pocket. Proc. 1st ESWC workshop on downscaling the semantic web, May 2012, Hersounissos, Greece. pp.6-13. ⟨hal-00768418⟩
238 Consultations
153 Téléchargements
