2D Sound-Source Localization on the Binaural Manifold - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The problem of 2D sound-source localization based on a robotic binaural setup and audio-motor learning is addressed. We first introduce a methodology to experimentally verify the existence of a locally-linear bijective mapping between sound-source positions and high-dimensional interaural data, using manifold learning. Based on this local linearity assumption, we propose an novel method, namely probabilistic piecewise affine regression, that learns the localization-to-interaural mapping and its inverse. We show that our method outperforms two state-of-the art mapping methods, and allows to achieve accurate 2D localization of natural sounds from real world binaural recordings.
Deleforge-MLSP-2012_camready.pdf (3.16 Mo) Télécharger le fichier
hal-00768657 , version 1 (22-12-2012)
Antoine Deleforge, Radu Horaud. 2D Sound-Source Localization on the Binaural Manifold. MLSP 2012 - IEEE Workshop on Machine Learning for Signal Processing, Sep 2012, Santander, Spain. pp.1-6, ⟨10.1109/MLSP.2012.6349784⟩. ⟨hal-00768657⟩
509 Consultations
548 Téléchargements
