Effective conditions for the reflection of an acoustic wave by low-porosity perforated plates - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Fluid Mechanics Année : 2014
This paper describes an investigation of the acoustic properties of a low-porosity perforated plate in a compressible ideal inviscid fluid in the absence of mean flow. The study shows in particular how the reflection and transmission coefficients of an acoustic plane wave produced by such a device can be expressed in terms of the Rayleigh conductivity of an isolated perforation by extending the approach introduced for the case of thick plates by Leppington and Levine, \textit{Reflexion and transmission at a plane screen with periodically arranged circular or elliptical apertures}, J. Fluid Mech., 1973, p.109-127. Lower and upper bounds for the Rayleigh conductivity of a perforation in a thick plate are usually derived from intuitive approximations and by reasoning based on physical observation. The paper addresses a mathematical justification of these approaches, yielding accurate bounds for various geometries, untilted or tilted, with a conical shape or an elliptical section. Accurate estimates of the Rayleigh conductivity for a single perforation have a direct impact on the precision of models used for predicting the acoustic behavior of a perforated plate mainly on the basis of its reflection and transmission coefficients. It is shown in this paper how asymptotic expansions can be used to derive first and second-order accurate, albeit approximate expressions of these coefficients, as well as of the effective compliance of the perforated plate.
soumission-jfm.pdf (566.9 Ko) Télécharger le fichier
hal-00769393 , version 1 (31-12-2012)
Sophie Laurens, Estelle Piot, Abderrahmane Bendali, M'Barek Fares, Sébastien Tordeux. Effective conditions for the reflection of an acoustic wave by low-porosity perforated plates. Journal of Fluid Mechanics, 2014, ⟨10.1017/jfm.2014.46⟩. ⟨hal-00769393⟩
539 Consultations
492 Téléchargements
