Linear Regression with Random Projections - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Machine Learning Research Année : 2012
Rémi Munos
  • Fonction : Auteur
  • PersonId : 836863
We investigate a method for regression that makes use of a randomly generated subspace $G_P$ (of finite dimension $P$) of a given large (possibly infinite) dimensional function space $F$, for example, $L_{2}([0,1]^d)$. $G_P$ is defined as the span of $P$ random features that are linear combinations of a basis functions of $F$ weighted by random Gaussian i.i.d.~coefficients. We show practical motivation for the use of this approach, detail the link that this random projections method share with RKHS and Gaussian objects theory and prove, both in deterministic and random design, approximation error bounds when searching for the best regression function in $G_P$ rather than in $F$, and derive excess risk bounds for a specific regression algorithm (least squares regression in $G_P$). This paper stresses the motivation to study such methods, thus the analysis developed is kept simple for explanations purpose and leaves room for future developments.
JMLR_random_proj_2012.pdf (558.98 Ko) Télécharger le fichier
hal-00771487 , version 1 (08-01-2013)
  • HAL Id : hal-00771487 , version 1
Odalric Maillard, Rémi Munos. Linear Regression with Random Projections. Journal of Machine Learning Research, 2012, 13 (1), pp.2735-2772. ⟨hal-00771487⟩
216 Consultations
381 Téléchargements
