Functional Regularized Least Squares Classi cation with Operator-valued Kernels - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Although operator-valued kernels have recently received increasing interest in various machine learning and functional data analysis problems such as multi-task learning or functional regression, little attention has been paid to the understanding of their associated feature spaces. In this paper, we explore the potential of adopting an operator-valued kernel feature space perspective for the analysis of functional data. We then extend the Regularized Least Squares Classification (RLSC) algorithm to cover situations where there are multiple functions per observation. Experiments on a sound recognition problem show that the proposed method outperforms the classical RLSC algorithm.
FRLSC.pdf (535.71 Ko) Télécharger le fichier
hal-00772406 , version 1 (11-01-2013)
Hachem Kadri, Asma Rabaoui, Philippe Preux, Emmanuel Duflos, Alain Rakotomamonjy. Functional Regularized Least Squares Classi cation with Operator-valued Kernels. 28th International Conference on Machine Learning (ICML), Jun 2011, Seattle, United States. pp.993--1000. ⟨hal-00772406⟩
266 Consultations
170 Téléchargements
