Communicating and trusting proofs: The case for foundational proof certificates - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
It is well recognized that proofs serve two different goals. On one hand, they can serve the didactic purpose of explaining why a theorem holds: that is, a proof has a message that is meant to describe the ''why'' behind a theorem. On the other hand, proofs can serve as certificates of validity. In this case, once a certificate is checked for its syntactic correctness, one can then trust that the theorem is, in fact, true. In this paper, we argue that structural proof theory and computer automation have matured to such a level that they can be used to provide a flexible and universal approach to proof-as-certificate. In contrast, the notion of proof-as-message is still evolving and deals with structures, such as diagrams and natural language texts, that are not yet well formalized.
fpc.pdf (146.67 Ko) Télécharger le fichier
hal-00772727 , version 1 (11-01-2013)
  • HAL Id : hal-00772727 , version 1
Dale Miller. Communicating and trusting proofs: The case for foundational proof certificates. 2013. ⟨hal-00772727⟩
224 Consultations
117 Téléchargements
