A Distinguisher for High Rate McEliece Cryptosystems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Information Theory Année : 2013
The Goppa Code Distinguishing (GD) problem consists in distinguishing the matrix of a Goppa code from a random matrix. The hardness of this problem is an assumption to prove the security of code-based cryptographic primitives such as McEliece's cryptosystem. Up to now, it is widely believed that the GD problem is a hard decision problem. We present the first method allowing to distinguish alternant and Goppa codes over any field. Our technique can solve the GD problem in polynomial-time provided that the codes have sufficiently large rates. The key ingredient is an algebraic characterization of the key-recovery problem. The idea is to consider the rank of a linear system which is obtained by linearizing a particular polynomial system describing a key-recovery attack. Experimentally it appears that this dimension depends on the type of code. Explicit formulas derived from extensive experimentations for the rank are provided for "generic" random, alternant, and Goppa codes over any alphabet. Finally, we give theoretical explanations of these formulas in the case of random codes, alternant codes over any field of characteristic two and binary Goppa codes.
MAYA2-UPMCINRIA-adist-2.0.pdf (251.01 Ko) Télécharger le fichier
hal-00776068 , version 1 (14-01-2013)
Jean-Charles Faugère, Valérie Gauthier-Umana, Ayoub Otmani, Ludovic Perret, Jean-Pierre Tillich. A Distinguisher for High Rate McEliece Cryptosystems. IEEE Transactions on Information Theory, 2013, 59 (10), pp.6830-6844. ⟨10.1109/TIT.2013.2272036⟩. ⟨hal-00776068⟩
425 Consultations
729 Téléchargements
