Superfast solution of Toeplitz systems based on syzygy reduction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Linear Algebra and its Applications Année : 2013
We present a new superfast algorithm for solving Toeplitz systems. This algorithm is based on a relation between the solution of such problems and syzygies of polynomials or moving lines. We show an explicit connection between the generators of a Toeplitz matrix and the generators of the corresponding module of syzygies. We show that this module is generated by two elements and the solution of a Toeplitz system T u=g can be reinterpreted as the remainder of a vector depending on g, by these two generators. We obtain these generators and this remainder with computational complexity O(n log^2 n) for a Toeplitz matrix of size nxn.
paper-hal.pdf (161 Ko) Télécharger le fichier
hal-00780556 , version 1 (24-01-2013)
Houssam Khalil, Bernard Mourrain, Michelle Schatzman. Superfast solution of Toeplitz systems based on syzygy reduction. Linear Algebra and its Applications, 2013, 438 (9), pp.3563-3575. ⟨10.1016/j.laa.2013.01.015⟩. ⟨hal-00780556⟩
251 Consultations
301 Téléchargements
