Neutrality in the Graph Coloring Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2013
The graph coloring problem is often investigated in the literature. Many insights about many neighboring solutions with the same fitness value are raised but as far as we know, no deep analysis of this neutrality has ever been conducted in the literature. In this paper, we quantify the neutrality of some hard instances of the graph coloring problem. This neutrality property has to be detected as it impacts the search process. Indeed, local optima may belong to plateaus that represents a barrier for local search methods. In this work, we also aim at pointing out the interest of exploiting neutrality during the search. Therefore, a generic local search dedicated to neutral problems, NILS, is performed on several hard instances.
RR-8215.pdf (486.5 Ko) Télécharger le fichier
hal-00781001 , version 1 (25-01-2013)
Marie-Eleonore Marmion, Aymeric Blot, Laetitia Jourdan, Clarisse Dhaenens. Neutrality in the Graph Coloring Problem. [Research Report] RR-8215, INRIA. 2013, pp.15. ⟨hal-00781001⟩
207 Consultations
428 Téléchargements
