Semantic adaptation of multimedia documents - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Multimedia Tools and Applications Année : 2011
Multimedia documents have to be played on multiple device types. Hence, usage and platform diversity requires document adaptation according to execution contexts, not generally predictable at design time. In an earlier work, a semantic framework for multimedia document adaptation was proposed. In this framework, a multimedia document is interpreted as a set of potential executions corresponding to the author specification. To each target device corresponds a set of possible executions complying with the device constraints. In this context, adapting requires to select an execution that satisfies the target device constraints and which is as close as possible from the initial composition. This theoretical adaptation framework does not specifically consider the main multimedia document dimensions, i.e., temporal, spatial and hypermedia. In this paper, we propose a concrete application of this framework on standard multimedia documents. For that purpose, we first define an abstract structure that captures the spatio-temporal and hypermedia dimensions of multimedia documents, and we develop an adaptation algorithm which transforms in a minimal way such a structure according to device constraints. Then, we show how this can be used for adapting concrete multimedia documents in SMIL through converting the documents in the abstract structure, using the adaptation algorithm, and converting it back in SMIL. This can be used for other document formats without modifying the adaptation algorithm.
Laborie-Euzenat-Layaida-MTAP.pdf (1.26 Mo) Télécharger le fichier
hal-00781024 , version 1 (25-01-2013)
Sébastien Laborie, Jérôme Euzenat, Nabil Layaïda. Semantic adaptation of multimedia documents. Multimedia Tools and Applications, 2011, 55 (3), pp.379-398. ⟨10.1007/s11042-010-0552-9⟩. ⟨hal-00781024⟩
775 Consultations
251 Téléchargements
