Low order approximation of the spherical nonreflecting boundary kernel for the wave equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Linear Algebra and its Applications Année : 2003
Jing-Rebecca Li
We find low order approximations to the spherical nonreflecting boundary kernel for the wave equation in three dimensions. First we express the Laplace transform of the kernel as a rational function by solving for the zeros of a modified Bessel function. Then we formulate a linear time-invariant dynamical system whose transfer function is this rational function. Finally we use the Balanced Truncation method to generate loworder approximations.We compare our approach with a direct L2 minimization approach where a rational approximation is expressed as the ratio of two polynomials.
Fichier non déposé
hal-00781117 , version 1 (25-01-2013)
  • HAL Id : hal-00781117 , version 1
Jing-Rebecca Li. Low order approximation of the spherical nonreflecting boundary kernel for the wave equation. Linear Algebra and its Applications, 2003. ⟨hal-00781117⟩
127 Consultations
0 Téléchargements
