Subspace-Based Algorithms for Structural Identification, Damage Detection, and Sensor Data Fusion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue EURASIP Journal on Advances in Signal Processing Année : 2007
This paper reports on the theory and practice of covariance-driven output-only and input/output subspace-based identification and detection algorithms. The motivating and investigated application domain is vibration-based structural analysis and health monitoring of mechanical, civil, and aeronautic structures.
1687-6180-2007-069136.pdf (352.49 Ko) Télécharger le fichier
1687-6180-2007-069136.xml (35.59 Ko) Télécharger le fichier
Format : Autre
hal-00784477 , version 1 (04-02-2013)
Michèle Basseville, Albert Benveniste, Maurice Goursat, Laurent Mevel. Subspace-Based Algorithms for Structural Identification, Damage Detection, and Sensor Data Fusion. EURASIP Journal on Advances in Signal Processing, 2007, 2007 (1), pp.069136. ⟨10.1155/2007/69136⟩. ⟨hal-00784477⟩
162 Consultations
283 Téléchargements
