QoS and Energy Management Coordination using Discrete Controller Synthesis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Green computing is nowadays a major challenge for most IT organizations. Administrators have to manage the trade-off between system performances and energy saving goals. Autonomic computing is a promising approach to control the QoS and the energy consumed by a system. This paper precisely investigates the use of synchronous programming and discrete controller synthesis to automate the generation of a controller that enforces the required coordination between QoS and energy managers. We illustrate our approach by describing the coordination between a simple admission controller and an energy controller.
delaval-gcm10.pdf (168.04 Ko) Télécharger le fichier
hal-00784999 , version 1 (05-02-2013)
  • HAL Id : hal-00784999 , version 1
Noël de Palma, Gwenaël Delaval, Eric Rutten. QoS and Energy Management Coordination using Discrete Controller Synthesis. 1st International Workshop on Green Computing Middleware (GCM'2010), Nov 2010, Bangalore, India. ⟨hal-00784999⟩
163 Consultations
201 Téléchargements
