Nonlinear Filtering with Transfer Operator - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a new nonlinear filtering algorithm that is shown to outperform state-of-the-art particle filters with resampling. Starting from the Itˆo stochastic differential equation, the proposed algorithm harnesses Karhunen- Lo'eve expansion to derive an approximate non-autonomous dynamical system, for which transfer operator based density computation can be performed in exact arithmetic. It is proved that the algorithm is asymptotically consistent in mean-square sense. Numerical results demonstrate that explicitly accounting prior dynamics entail significant performance improvement for nonlinear non-Gaussian estimation problems with infrequent measurement updates, as compared to the performance of particle filters.
KLPFfilterACC2013Final.pdf (205.21 Ko) Télécharger le fichier
hal-00785159 , version 1 (05-02-2013)
Parikshit Dutta, Abhishek Halder, Raktim Bhattacharya. Nonlinear Filtering with Transfer Operator. IEEE American Control Conference, Jun 2013, Washington, D.C., United States. pp.3069-3074, ⟨10.1109/ACC.2013.6580302⟩. ⟨hal-00785159⟩
210 Consultations
366 Téléchargements
