Speed Scaling to Manage Temperature. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider the speed scaling problem where the quality of service objective is deadline feasibility and the power objective is temperature. In the case of batched jobs, we give a simple algorithm to compute the optimal schedule. For general instances, we give a new online algorithm, and obtain an upper bound on the competitive ratio of this algorithm that is an order of magnitude better than the best previously known bound upper bound on the competitive ratio for this problem.
tapas11.pdf (154.14 Ko) Télécharger le fichier
hal-00786200 , version 1 (03-09-2013)
Leon Atkins, Guillaume Aupy, Daniel Cole, Kirk Pruhs. Speed Scaling to Manage Temperature.. TAPAS - 1st International ICST Conference on Theory and Practice of Algorithms in (Computer) Systems, 2011, Rome, Italy. pp.9-20, ⟨10.1007/978-3-642-19754-3_4⟩. ⟨hal-00786200⟩
114 Consultations
223 Téléchargements
