High-Precision Pointing on Large Wall Displays using Small Handheld Devices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rich interaction with high-resolution wall displays is not limited to remotely pointing at targets. Other relevant types of interaction include virtual navigation, text entry, and direct manipulation of control widgets. However, most techniques for remotely acquiring targets with high precision have studied remote pointing in isolation, focusing on pointing efficiency and ignoring the need to support these other types of interaction. We investigate high-precision pointing techniques capable of acquiring targets as small as 4 millimeters on a 5.5 meters wide display while leaving up to 93 of a typical tablet device's screen space available for task-specific widgets. We compare these techniques to state-of-the-art distant pointing techniques and show that two of our techniques, a purely relative one and one that uses head orientation, perform as well or better than the best pointing-only input techniques while using a fraction of the interaction resources.
headpad-hal-v2.pdf (413.12 Ko) Télécharger le fichier
pointing_ultrawalls_CHI2013.mp4 (36.94 Mo) Télécharger le fichier
Format : Figure, Image
hal-00786532 , version 1 (08-02-2013)
hal-00786532 , version 2 (01-05-2013)
Mathieu Nancel, Olivier Chapuis, Emmanuel Pietriga, Xing-Dong Yang, Irani Pourang, et al.. High-Precision Pointing on Large Wall Displays using Small Handheld Devices. 31th international conference on Human factors in computing systems, Apr 2013, Paris, France. pp.831-840, ⟨10.1145/2470654.2470773⟩. ⟨hal-00786532v2⟩
1186 Consultations
1058 Téléchargements
