Abstract Acceleration in Linear relation analysis (extended version) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2013
Linear relation analysis is a classical abstract interpretation based on an over-approximation of reachable numerical states of a program by convex polyhedra. Since it works with a lattice of infinite height, it makes use of a widening operator to enforce the convergence of fixed point computations. Abstract acceleration is a method that computes the precise abstract effect of loops wherever possible and uses widening in the general case. Thus, it improves both the precision and the efficiency of the analysis. This research report gives a comprehensive tutorial on abstract acceleration: its origins in Presburger-based acceleration including new insights w.r.t. the linear accelerability of linear transformations, methods for simple and nested loops, recent extensions, tools and applications, and a detailed discussion of related methods and future perspectives. This is the long version of a paper under submission.
RR_LIFL_soushalV1.pdf (617.93 Ko) Télécharger le fichier
hal-00787212 , version 1 (11-02-2013)
  • HAL Id : hal-00787212 , version 1
Laure Gonnord, Peter Schrammel. Abstract Acceleration in Linear relation analysis (extended version). 2013. ⟨hal-00787212⟩
343 Consultations
368 Téléchargements
