Two properties of two-velocity two-pressure models for two-phase flows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Communications in Mathematical Sciences Année : 2014
Jean-Marc Hérard
Khaled Saleh
We study a class of models of compressible two-phase flows. This class, which includes the Baer-Nunziato model, is based on the assumption that each phase is described by its own pressure, velocity and temperature and on the use of void fractions obtained from averaging process. These models are nonconservative and non-strictly hyperbolic. We prove that the mixture entropy is non-strictly convex and that the system admits a symmetric form.
CHSS-1.pdf (235.04 Ko) Télécharger le fichier
hal-00788902 , version 1 (15-02-2013)
hal-00788902 , version 2 (12-04-2013)
  • HAL Id : hal-00788902 , version 2
Frédéric Coquel, Jean-Marc Hérard, Khaled Saleh, Nicolas Seguin. Two properties of two-velocity two-pressure models for two-phase flows. Communications in Mathematical Sciences, 2014, 12 (3). ⟨hal-00788902v2⟩
737 Consultations
648 Téléchargements
