Well-posedness for a one-dimensional fluid-particle interaction model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Mathematical Analysis Année : 2014
The fluid-particle interaction model introduced by the three last authors in [J. Differential Equations, 245 (2008), pp. 3503-3544] is the object of our study. This system consists of the Burgers equation with a singular source term (term that models the interaction via a drag force with a moving point particle) and of an ODE for the particle path. The notion of entropy solution for the singular Burgers equation is inspired by the theory of conservation laws with discontinuous flux developed by the first author, Kenneth Hvistendahl Karlsen and Nils Henrik Risebro in [Arch. Ration. Mech. Anal., 201 (2011), pp. 26-86]. In this paper, we prove well-posedness and justify an approximation strategy for the particle-in-Burgers system in the case of initial data of bounded variation. Existence result for L∞ data is also given.
BP.pdf (250.37 Ko) Télécharger le fichier
hal-00789315 , version 1 (18-02-2013)
  • HAL Id : hal-00789315 , version 1
Boris Andreianov, Frédéric Lagoutière, Nicolas Seguin, Takéo Takahashi. Well-posedness for a one-dimensional fluid-particle interaction model. SIAM Journal on Mathematical Analysis, 2014, 46 (2). ⟨hal-00789315⟩
644 Consultations
412 Téléchargements
