An ontological approach for modeling technical standards for compliance checking - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper gives an overview of a formal semantic-based approach of modeling some regulations in the photovoltaic field to help the delivering of technical assessments at the French scientific center on Building Industry (CSTB). Starting from regulatory texts, we first explicit SBVR rules and then formalize them into ontology-based rules in the SPARQL language. These are exploited in the modeling of the compliance checking process required for the delivering of technical assessments.
paper_44.pdf (48.81 Ko) Télécharger le fichier
hal-00790338 , version 1 (19-02-2013)
  • HAL Id : hal-00790338 , version 1
Khalil Riad Bouzidi, Catherine Faron Zucker, Bruno Fies, Nhan Le Thanh. An ontological approach for modeling technical standards for compliance checking. The Fifth International Conference on Web Reasoning and Rule Systems, RR 2011, Aug 2011, Galway, Ireland. ⟨hal-00790338⟩
248 Consultations
243 Téléchargements
