Validation of a semi-classical Signal analysis method for Stroke volume variation assessment: a comparison with the PiCCO technique - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Journal Articles Annals of Biomedical Engineering Year : 2010
This study proposes a Semi-Classical Signal Analysis (SCSA) method for stroke volume (SV) variations assessment from arterial blood pressure measurements. One of the SCSA parameters, the first systolic invariant (INVS1), has been shown to be linearly related to SV. To technically validate this approach, the comparison between INVS1 and SV measured with the currently used PiCCO technique was performed during a 15-min recording in 20 mechanically ventilated patients in intensive care. A strong correlation was estimated by linear regression and cross-correlation analysis (mean coefficient = 0.90 ± 0.01 SEM at the two tests).
Dates and versions
inria-00527442 , version 1 (19-10-2010)
Identifiers
Cite
Taous-Meriem Laleg-Kirati, Claire Médigue, Yves Papelier, François Cottin, Andry van de Louw. Validation of a semi-classical Signal analysis method for Stroke volume variation assessment: a comparison with the PiCCO technique. Annals of Biomedical Engineering, 2010, 38 (12), pp.3618-3629. ⟨10.1007/s10439-010-0118-z⟩. ⟨inria-00527442⟩
258 View
0 Download
Share
