AROMA results for OAEI 2009
This paper presents the results obtained by AROMA for its second participation to OAEI. AROMA is an hybrid, extensional and asymmetric ontology alignment method that makes use of the association paradigm and a statistical interestingness measure, the implication intensity. AROMA performs a post-processing step that includes a terminological matcher. This year we modify this matcher in order to improve the recall obtained on real-case ontology, i.e. anatomy and 3xx tests.
